Help with codes
Old Aug 6, 2005 | 11:21 PM
Rollmodel's Avatar
Question Help with codes
The SES light in my 2001 Trans Am recently came on, i took it to autozone and had them pull the codes and what they gave me was P0420 and P1416, they told me it was something to do with the catalyst system, but i dont see that happening, does anyone have any better detail on these codes?
Old Aug 6, 2005 | 11:38 PM
JEB Garner's Avatar
Default Codes
Your codes are:
DTC P1416 Secondary Air Injection (AIR) System Bank 2
DTC P0420 Catalyst System Low Efficiency Bank 1
Thought that may help
Old Aug 7, 2005 | 09:05 AM
2001NBMZ28's Avatar
P1416 is a bad passenger side air check valve, they get gunked up sometimes and stop working - easy to replace yourself, about $15 at a local parts store.
P0420 could be the post cat driver's side 02, but most likely the cat itself is bad - the cat is covered under federal emissions warranty for 8 yrs/80K - dealer will replace it free.
Both are fairly common codes, more info in this forum if you do a search for them - also search for P0430 and P1415, same codes just for the opposite bank. And welcome to the board.
Old Aug 7, 2005 | 10:48 PM
Rollmodel's Avatar
Thanks, those will help alot, i need to get this **** fixed quick, thanks guys.
Old Aug 13, 2005 | 06:01 PM
Rollmodel's Avatar
Anybody have any pictures of the passenger side air check valve, i want to check it out, but really have no clue what it is, or how to do it, would help a lot , thanks.
Old Aug 13, 2005 | 06:16 PM
2xLS1's Avatar
Look at the pics I posted here. https://ls1tech.com/forums/generation-iii-external-engine/362754-difference-air-systems.html It is #4 in the 98-99 illustration and #30 in the 00-02 illustration.
Old Aug 14, 2005 | 10:47 AM
Rollmodel's Avatar
thanks a lot 2xLS1
