Techedge WB with Hptuners
Old Aug 8, 2005 | 06:40 AM
SikHabibBroCuz's Avatar
Default Techedge WB with Hptuners
Hi guys i have a 2004 Holden Commodore with Hptuners and im looking at getting one of the techedge DIY WB Kits. Im trying to decide between the 2AO and 2EO DIY kits, Has anyone got one of these? Are they any good? What Senser did you get with it?
http://wbo2.com/2a0/kit.htm
http://wbo2.com/2e0/kit.htm
Also its says both kits can simulate narrow band O2 does that mean i can take out the stock o2 and put my wbO2 in the stock bung?
Thanks Heaps
Ronny
Old Aug 9, 2005 | 11:05 PM
cheechz's Avatar
i have the 2a0 kit. works great. tech support is very good. i am using the 7057 sensor. i cant really recommend one over the other. i guess its supposedly slightly slower than the more expensive ones, but whatever..
i dont know about the nb sim idea. you would have to wire the sensors nbsim output to your cars ECM. i just went with the "drill your own additional bung" option.
Old Aug 16, 2005 | 04:38 AM
thanks cheechz. Do you know what the thermocouple inputs are or what there used for on the 2Ao kit?. The only thing stopping me from buying the 2Eo kit is not knowing if i need these inputs as they are only avaible with the 2ao kit
thanks
ronny
Old Aug 16, 2005 | 05:50 AM
Holden LS1 Tonner's Avatar
Hi Ronny
I have the 2Ao and HPT and they work well but the only output that i use is the WBlin output and i dont tend to use the on board loging , you may find that the 2C0 would be just as good to use with HPT . The lc1 is also good value for money and uses the same WB02 sensor as the tech edge is avalable with .
Old Aug 16, 2005 | 04:41 PM
cheechz's Avatar
i believe the thermocouples are used for logging exhaust gas temp. i have never used them.
Old Aug 16, 2005 | 05:11 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
why not use the innovate controller?
www.dynotunenitrous.com
pm us as we can sell you one cheap!
dan
