HP TUNERS help on fuel tabs...
Old Aug 10, 2005 | 12:21 PM
MECHAM's Avatar
Default HP TUNERS help on fuel tabs...
in HP Tuners..can some1 verify that the following are for adjust injector offset and power enrich for injectors
Injector Offset table == Fuel Control --> General Fuel --> Flow Rate vs KPA
the lower the number .. the more fuel they will flow correct?
Code:
58.35	58.35	58.35	58.35	58.35	58.35	58.35	58.04	56.98	55.93	54.94	53.88	52.83	51.65	49.67	48.67	47.62
Power Enrichment for injectors == Fuel Control --> Power Enrich --> V8 mult vs. RPM
the higher the number .. the more fuel they will flow correct?
Code:
1.159	1.159	1.159	1.159	1.159	1.159	1.209	1.209	1.209	1.209	1.209	1.209	1.209	1.22	1.22	1.22	1.22	1.22	1.22
are those the tabs??...thx
Old Aug 10, 2005 | 01:07 PM
horist's Avatar
Flow Rate vs KPA is the table you want to scale the injectors... not many adjus the offset table
and the V8 Mult vs RPM is the one you want to adjust for fueling
Higher the number the richer the car runs (those values are divisors... Stoich (on the General Tab) divided by the value in PE yields the command AFR
