Adjusting timing after ve table
Thanks
Dave
Dave
All the tuning docs say VE first, then PE and timing. But none say the timing may throw off your VE and you'll need to tweak it.
However when you change timing you do change fueling requirements....
LS1PWR, I'd like to know too because I read a post from WS6FirebirdTA00 about the same thing and had the same problem you did; bypass or normal? Either one didn't change the timing.
