having a problem logging maf hz and dyn air in hptuners
Old Aug 17, 2005 | 09:44 PM
OneBad98Z's Avatar
Default having a problem logging maf hz and dyn air in hptuners
ive been trying to log maf hz and dynamic airflow in order to adjust the maf table, in hp tuners the only place i can find it is chart display, ive selected it and logged but neither one leaves the zero mark? what am i doing wrong here guys, in the gauge display it shows the maf needle moving and i did change the fail frequency back from 0
Thanks for all the help so far, it has been a lifesaver,
Greg
Old Aug 18, 2005 | 11:28 AM
RedHardSupra's Avatar
first you gotta add it in the table.
then you gotta set the right scaling on the graph in order to see it. so a reasonable max would be like 500g/sec or 50lb/min for max, depending on your units (also settable in the table)
