HPT and LC1 problem.....
It jumps from 13-14-15-14-13-14-13-15-14... or something like that...
Even with the engine off, it will not stabilize, it just jumps very quickly between AFR values like that...
I also did some voltmeter tests.... and.... the LC1 output voltage is extremely stable....
So I programmed my LC1 to output 1.5V whatever AFR it reads...
On the voltmeter I see a constant 1.492V
But on HP tuners I see anywhere from 1.3 to 1.7 volts and it is going evewhere in between these two values extremely fast at random...
Then I tried to hook up a 1.5 V battery to HP Tuners, and tada... a steady 1.59V....
So... Steady LC1 Output, and battery voltage indicate steady in hp...
Now what is my problem here?
BTW I use a desktop computer for these tests... Should I use a laptop instead?
