Help!!!!!!!!!
Old Aug 19, 2005 | 05:11 PM
pro2low64's Avatar
Default Help!!!!!!!!!
i have a lt1 out of a 95 corvette i have been told that it is a obdII and i have also been told that it is a obdI with a obII diagnostics output......i need to know what it is so i know what trans i can use cuase it isnt in the same car i am outting it into a 64 nova.....I NEED HELP!!!!!!
Old Aug 19, 2005 | 07:16 PM
felton316's Avatar
95's should be OBD1 with the trapizoid OBD2 plug.
Old Aug 19, 2005 | 09:49 PM
pro2low64's Avatar
trapizoid?
like the shape cuase there are 4 plugs and they are rectangles
Old Aug 19, 2005 | 10:54 PM
99SS-T's Avatar
Do you mean the connector that is right under the dash? The car is deinatly a OBD1. GL
John
Old Aug 19, 2005 | 11:41 PM
felton316's Avatar
Originally Posted by pro2low64
trapizoid?
I meant for the diagnostic plug under the dash to be trapiziod (like the OBD2 cars). The four plugs where the PCM plugs into the wiring harness will be the same as the OBD1 cars.
Old Aug 21, 2005 | 05:42 PM
pro2low64's Avatar
i dont have the car so i cant look under the dash lol.......but i actually found a website that tells you what it is if you have the numbers of the comp
