IAC (TPS) Idle relearn procedure
Old Aug 22, 2005 | 09:54 AM
Sneakyws6's Avatar
On the tree
Default IAC (TPS) Idle relearn procedure
Ok I have searched for an hour now and no one in their post has told how to do the relearn procedure.
My dad pulled his IAC out and now the truck is idling funny. Can anyone please post up how to do the relearn procedure for me.
Thanks in advance...
Old Aug 22, 2005 | 02:47 PM
SSpdDmon's Avatar
A PCM reset should get you an IAC relearn. There's tons of posts on how to reset the pcm.
Old Aug 23, 2005 | 03:07 PM
Viper's Avatar
Put key in ON position
Unplug IAC
Turn key off
Wait 30 seconds
Turn key on, leave on for 30 seconds. You should see a SES light now too.
Turn key off.
Plug IAC back in.
Turn key on.
If you can, verify with a scanner ( with key ON only, not car running ) that with your foot off the gas it's reading 0%, and at WOT it's reading 100%.
Your done.
Now here's an IDLE relearn:
PCM Idle Learn Procedure:
Automatic Transmission:
1 Turn off the ignition
2 Restore the PCM battery feed
3 Turn Off the AC controls
4 Set the parking brake and block the drive wheels
5 Start the engine
6 Allow the engine coolant temperature to reach 176 degrees F
7 Shift the transmission selector into the drive range
8 Allow the engine to idle for 5 minutes
9 Turn on the AC controls (Omit for 2000-01 model)
10 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
11 Shift the transmission selector into Park
12 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
13 Turn off the AC controls (Omit for 2000-01 model)
14 Allow the engine to idle for 5 minutes
15 Turn off the engine for 15 seconds
Manual Transmission:
1 Turn Off the ignition
5 Transmission in neutral
6 Start the engine
7 Allow the engine coolant temperature to reach 176 degrees F
8 Turn on the AC controls (Omit for 2000-01 model)
9 Allow the engine to idle for 5 minutes (Omit for 2000-01 model)
10 Turn off the AC controls (Omit for 2000-01 model)
11 Allow the engine to idle for 5 minutes
12 Turn off the engine for 15 seconds
Old Aug 23, 2005 | 07:54 PM
P Mack's Avatar
Viper, I think you're talking about tps, not iac. Since when do people need to reset their iac's anyway?
Old Aug 24, 2005 | 06:27 AM
Viper's Avatar
Doh! I wrote TPS reset.
Old Jul 21, 2025 | 07:04 PM
BigBoyWS6's Avatar
Well Viper……your write up that you thought was for TPS……..I just did it for my new IAC valve install because in a week I couldn’t get it to operate properly, it was all over the place.
Your procedure worked it idles perfectly. First bump of the key and it’s BAM right on idle, no chasing the idle up and down until it settles on 900 rpm. Solidly goes to 900 instantly.
So…..as we all know, these PCMs are not all the same, they have minds of their own. If in fact that was a TPS idle relearn, I’m here to tell everyone they can try it for an IAC valve also, because their PCM might like it.
Thanks.
