HELP!!!P0420 code
Old Aug 29, 2005 | 10:53 PM
SeVeReDiStOrTiOn's Avatar
Default HELP!!!P0420 code
I keep getting a p0420 code...usually when at higher rpms. the scanner said it was a bank 1 cat below threshold...so what exactly is the prob? is it the rear o2 at bank 1...the cat...or is there a motor prob that made the cat go bad. Oh yea....which side is bank 1 Thanks ahead of time
Old Aug 29, 2005 | 11:28 PM
SmokingWS6's Avatar
bank 1 catalyst low efficiency.
You might have a bad cat, or possibly a bad rear o2 on the drivers side. its bank 1 sensor 2. Or perhaps its smoked to much pot, po420.. lol.
Old Aug 29, 2005 | 11:39 PM
hmmm...i guess i'll go with the cheaper option and replace the o2...if it is the cat, what would cause it to go bad? It's only a 2000...do you think it's running rich? i have noticed my tailpipes have more black soot then i would like
Old Aug 30, 2005 | 10:12 PM
Y2KblkTA's Avatar
just to fill you in, the emissions system, (cats) should carry a 8 year 80,000 mile warranty no matter what. just check into it. my 00 ws6 pulls that code intermittently, and the rear o2's are heated, so they are pricey.
