can someone help with getting LM-1 data
Old Aug 30, 2005 | 09:09 AM
WS6FirebirdTA00's Avatar
Default can someone help with getting LM-1 data
helping a guy on the board out iwth his LM-1. i was able to open the data up but can someone tell me the proper way to set it up to where it can record throttle position and rpm and how to set the max and min values on the chart? he sent me all the info he had on it but its still unclear to me and i know a lot of guys run this so hopefully you all can help out.
Old Aug 30, 2005 | 11:37 AM
to the top
Old Aug 30, 2005 | 07:03 PM
to the top, how do you log where i can separate the data by TPS and RPM?
Old Aug 31, 2005 | 12:50 PM
horist's Avatar
As mentioned in the other thread... you need either their aux box or the RPM Converter... then you need to splice into the wires at the PCM to get a signal... once done you can configure the LM-1 w/the softwar it came with to log different items along w/the AFR (no way around this since the LM1 doesn't know how to communicate w/the OBDII port... )
Old Aug 31, 2005 | 12:58 PM
ok thanks man thats what i was wanting to know. i dont actually have the unit in hand just trying to help the guy out. thanks again
Old Jan 11, 2013 | 02:21 PM
ws9 k1500's Avatar
so.. here i sit just did the 4 wire harness mod on my buddies k 1500 double checked twice now I get low voltage codes for throttle,crank and cam position sensors it fires up great for about 3-5 seconds then dies! ok feel free to call me an idiot but wtf? i have read in your forums about ecm flashing and vats. i believe vats is negated by the 4 wire mod is this correct? lastly can anyone tell me a good place to have my ecm flashed in the spokane wa. area? ps this occurs using the ecm from the donor truck and also the ecm from my 01 firebird
