Timing to pull?
Old Sep 1, 2005 | 05:10 AM
beardWS6's Avatar
Default Timing to pull?
You can see the car in sig. I have H/C and 150 shot with everything. T-rex inline fuel pump, 255 walb in-tank, 42lb injects and got fast fuel rails going on this week. So fuel will not be a issue. Right now I believe I have 2-3 degrees pulled. Do I need it pulled. Can I put it back in and be safe for the 150 wet shot!! You can see I run the 90/90 set-up and all. Trying to get the car to run alittle better N/A. I don`t spray all the time so it sorta sucks being tuned for spray like that. Tell me your thoughts, Thanks. My car is in my Sig!
__________________
