4 codes need help
P1539 A/C Clutch Status Circuit High Voltage
P0300 Engine Misfire Detected
P0122 Throttle Position (TP) Sensor Circuit Low Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
What do i need to do to fix these. The car is running like **** and shakes like a ****. It was fine i was sitting in the parking lot for like 10mins went into the store came back out and it was shaking after i started it.
What would cause the low voltage in the TPS? Should i just replace the TPS sensor or is something else causeing the problem? All the plugs and wires are only have about 4k on them. So i don't know why they would be misfireing.
