Low Traction Light Coming On ???
Old Sep 3, 2005 | 11:35 PM
02 Camaro SS's Avatar
Default Low Traction Light Coming On ???
I was just driving my car and all of a sudden when I hit the brakes before a stop sign, the pedal was pushing up like when the ABS is activated and the "Low Trac" light came on. From then on, more than half the times I hit the brakes the same thing would happen. I have stock rims and tires and I've had a 4 channel 12 bolt for 2 years now and that's never happened before. I tried shutting the car off but that didn't help at all. Does anyone know what would cause this?
Old Sep 3, 2005 | 11:52 PM
racecar's Avatar
Brake pad failure, low brake fluid, rubber brake hose leaking, vaccume hose to power brake leaking, just a few ideas.
Old Sep 5, 2005 | 12:01 PM
Is there anything in particular i can look for to narrow the choices down at all?
Old Sep 5, 2005 | 01:10 PM
TAQuickness's Avatar
Make a list, start at the front and work your way back. Process of elimination will narrow the list down fairly quick.
