PCM Install
Thanks
Install new PCM
not sure of an actual procedure.... remove the plastic caps from your PCM..... unscrew the 2 7mm bolts... disconnect the wiring harness connectors.... pull your PCM out... put your new PCM in... screw the 7mm bolts back in , replace plastic caps.... you're done..
It's not very difficult....
