Timing Table
Old Sep 12, 2005 | 11:22 AM
ORANGE JUICE1's Avatar
Default Timing Table
I was in the process of tuning and had the car in SD tune and had smoothed out the VE. I took the car to the track but my MPH was down 3 mph. Should I have copied the high octane timing table into the low octane?
Old Sep 12, 2005 | 11:31 AM
SMOKINV8's Avatar
If you've disabled your MAF, then you're running off of the low octane table.
If I were you, I'd copy it over. Just make sure you've got good gas in the car.
Old Sep 12, 2005 | 11:47 AM
bowtieman81's Avatar
smokin is absolutely right. I just made that same mistake this past weekend.
Old Sep 12, 2005 | 11:55 AM
Thanks for the replys. I will have to try the new tune with the correct timing table.
