Throwing a bunch of codes...
Old Sep 12, 2005 | 11:55 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Default Throwing a bunch of codes...
I need to some help here. My SES light went off a couple days ago, figured it was the same code I have been getting since I put on the headers. Turns out it was, its P0135 (o2 sensor). So I know what to do there.
Also got a random misfire code (P0300) - is it because of the other codes that were thrown?
Anyway the scanner read 5 codes : P0135 , P0300 , P0443 , P0481/P0480. The code that I am most worried about is the P0443 code (EVAP system). Where should I start with this one? cause I am lost. Whats the most common reason for this code to be thrown?
Also the codes P0481/0480 (fans), not real sure on where to start with them as well.
Tried searching, found some stuff but I still need some help.
Any help is appreciated, thanks .
Old Sep 13, 2005 | 06:52 PM
Lithium's Avatar
nevermind. A couple things were loose, got it solved.
