Show me your timing tables !
Old Sep 16, 2005 | 11:53 AM
dummer's Avatar
Default Show me your timing tables !
Hi,
Have LS1edit,
I got my fuel trims about right, now trying to get my timing tweaked best for this cam (.581/.581, 224/224, 112LSA) and Patriot stg. 2 heads. I've found the beast really wakes up with about 4 deg. added, as far a throttle response, etc. but adding that much to the whole Hi Oct. table, not good. So I need to taper the advance and scale somehow...
Trying to get a handle on how to scale the table.
Could anyone please post some examples of their tuned timing tables for a similar cam/heads combo? It is a '98 LS1 with stock compression.
Just want to see some examples of what other have done...
Old Sep 16, 2005 | 01:57 PM
technical's Avatar
Here's a pic of the graph. This is for a TR224/112 which is similar to your cam. I also have Patriot stage II's and stock compression.
I can get a csv file if that would be more helpful.
Old Sep 16, 2005 | 02:22 PM
dummer's Avatar
thanks, technical
that helps, but csv file would be better
any way you could send me one or post?
kthomas@knology.net
Old Sep 18, 2005 | 07:41 PM
technical's Avatar
Sure can. I have to pull it off the laptop first... then I'll post it up.
Old Sep 19, 2005 | 11:46 AM
technical's Avatar
Here ya go. It's formatted ',' delimited...just rename to .csv
File Type: txt
Old Sep 19, 2005 | 05:27 PM
bmfcamaro's Avatar
is this an m6 or auto. also what octane gas??
Old Sep 19, 2005 | 08:34 PM
technical's Avatar
M6 running 93 octane.
