timing table
Old Sep 19, 2005 | 11:31 AM
badaSS346's Avatar
Default timing table
If i were to copy the high octane timing table to the low octane timiming table, would the pcm stil pull timing if it detects knock? Also, is 25.5 degrees of advance high, low, or ok.
Old Sep 19, 2005 | 11:33 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Yes, KR is still active.
And 25.5 degrees where? The timing table has a lot of values...
Old Sep 19, 2005 | 11:36 AM
badaSS346's Avatar
25.5 at wot. From 3500 all the way to 6200.
Old Sep 19, 2005 | 11:51 AM
MeentSS02's Avatar
Sounds okay...as long as you aren't getting any knock, it should be fine.
Old Sep 19, 2005 | 07:15 PM
Rays C5's Avatar
Not to high jack the thraed but why is 98s/99 ls1 wot timing higher than 2000 and up??? Mines stock is 29 in the extreme load/rpm range. I know the 98 had a slightly more aggressive cam(bearly) But all else is relatively equal. Wher I see 22/24 the max in the same given area.
Old Sep 19, 2005 | 07:19 PM
Checkmate's Avatar
Different cam, as you said and the ls1 intake.
Old Sep 20, 2005 | 08:17 AM
MeentSS02's Avatar
Yep...my car in particular doesn't like a whole lot of timing at all. I run about 20-25 degrees max at WOT.
