LS1edit problem..
After my computer damaged and the LS1edit file on same computer, how i could return the file after my computer is damage?? i need any help to finish this problem please
I try to read the file on the LS1edit but there's a message it's ( receive VIN # )
what i should to do guys??
Regards
I'm assuming you did not do this. I think the only fix is to have a GM dealer reflash the PCM for $100 or so. You may have to tow (push) it there if it does not run.
