injector flow rate
Old Sep 24, 2005 | 01:23 PM
Recon12thman's Avatar
Default injector flow rate
i have hp tuners and i have recently installed 42.5 lb lucas injectors does anyone have a table or number for them so i can input the data, and what a good a/f ratio to run with these and n/a
Old Sep 24, 2005 | 01:27 PM
oange ss's Avatar
need to know what fuel pressure they're rated at.....AFR 12.8@WOT
Old Sep 24, 2005 | 01:40 PM
runnin at 58 psi the whole system
Old Sep 24, 2005 | 02:07 PM
oange ss's Avatar
no, what fuel pressure are the injectors are rated...i.e. the test pressure for the advertized rating, some are 40 psi, some are 45 psi
Old Sep 24, 2005 | 02:17 PM
RedHardSupra's Avatar
Code:
Injector Flow (g/sec)	6.15258	6.190924745	6.229033451	6.266910425	6.304559843	6.341985758	6.379192104	6.4161827	6.452961256	6.489531379	6.525896571	6.56206024	6.5980257	6.633796174	6.6693748	6.704764631	6.739968642
Injector Flow (lb/hr)	48.83086114	49.13518988	49.43764526	49.73826147	50.03707164	50.33410795	50.62940161	50.92298295	51.2148814	51.50512559	51.79374332	52.08076163	52.36620682	52.65010447	52.9324795	53.21335613	53.49275797
Injector Flow (lb/min)	0.813847686	0.818919831	0.823960754	0.828971024	0.833951194	0.838901799	0.84382336	0.848716383	0.853581357	0.85841876	0.863229055	0.868012694	0.872770114	0.877501741	0.882207992	0.886889269	0.891545966
Old Sep 24, 2005 | 03:00 PM
thanks guys new question i have a slp maf do i need to tune that table and if so what numbers do i have to change
Old Sep 24, 2005 | 07:13 PM
you need to start reading the stickies i gave you a freebie with putting in the numbers for you into the spreadsheet that's in the stickies, but the next question you have to read and fix yourself. it's all there
