Rough idle
Old Sep 30, 2005 | 09:54 AM
Nasty Hawk's Avatar
Default Rough idle
Currently in the mist of getting my car tuned and having some problems. Car has a hard time finding idle. We set it up to a open loop and still doing it. Car before tune always had a problem with throwing 02 sensor codes (SLP LT's) and it would surge at lights and sometimes even stall out. so i had the rears deleted and still doing it. Now we are doing open loop and still same thing.. any help??
Old Sep 30, 2005 | 10:24 AM
foff667's Avatar
LS1TECH Sponsor
ok youve set the car to open loop & deleted the rear o2's, what else have you done to try and fix the idle? Have you drilled the TB? Have you touched the idle set screw? Have you touch the base airflow table? Have you bumped your idle up? Where In PA are you? If your close enough I could probably help you out.
Old Sep 30, 2005 | 12:04 PM
Nasty Hawk's Avatar
I have Matt from Harris Speed Works on it now, so hopefully everything will work out. Was just wondering if anyone ever had a similar problem.
Old Sep 30, 2005 | 12:11 PM
foff667's Avatar
LS1TECH Sponsor
not with that small of a cam
