not to hijack this thread, but question to AEM, will this support a maf sensor, or will it be a Speed density only setup? I like the idea for the real time LS1 tuning tool ;) Some features that would be nice would be 802.11x wireless, for the no cable approach. Just a laptop and your done. Ryan |
FAST does real time changing. but, that means complete removal of your PCM and converting over to FAST. |
You can run a MAF, MAP or TPS as your load input. It will work with both frequency based and 0-5V MAF's, any MAP sensor you can throw at it (5 Bar Anyone?) or any TPS your heart desires. Plus, even though it is a full standalone, it's plug and play so it plugs in right into the PCM connectors. No need to build a wiring harness. It will also be able to run the dashboard and do everything the stock PCM does except the OBDII functions - We probably will not add in that because of the added complexity - and, of course, tuning in real time - the only way to go IMHO. |
yes .,call me i have been a very busy guy:)
Originally Posted by Craig Moates
(Post 3577093)
Folks, Are there any options out there right now for LS1 realtime tuning? If so, what is the price point? Would it be affordable, and even competitive, with other products that have been around for long enough? I mean, what would it take for the typical enthusiast consumer to be able to enjoy make changes to their LS1 tuning in realtime while the car is running? Would functionality like this be integrated with high-speed datalogging? Obviously, it would need to be at LEAST USB-based. What software support would it have? EFI Live? TunerCat? HP Tuners? DHP Tuners? Some other upstart software? Hmm... Best regards, -Craig |
For 6 years? |
© 2024 MH Sub I, LLC dba Internet Brands
