Any way to check odometer with tuners?
Old Oct 2, 2005 | 03:14 PM
Hocky's Avatar
Default Any way to check odometer with tuners?
I don't have an odometer in the car... is that information accessible from somewhere within tuners by chance?
Old Oct 2, 2005 | 03:46 PM
Hocky's Avatar
Originally Posted by kbracing96
The odometer memory is only stored in the speedo cluster. The PCM dosen't store it.
Damn.... I thought that may be the case, but was hoping otherwise. Oh well.
Old Oct 2, 2005 | 03:47 PM
kbracing96's Avatar
Old Oct 2, 2005 | 08:12 PM
Phoenix 5.7's Avatar
i believe that you are wrong. there is no way to program a cluster. it just has a display. I don't think it is possible to view it from the PCM though
Old Oct 2, 2005 | 08:51 PM
bmfcamaro's Avatar
i believe the dealer can.
Old Oct 2, 2005 | 09:35 PM
kbracing96's Avatar
If you take a cluster from one car and put it in another car it will still have the same milage as it did in the FIRST car. Most dealer don't have the equipment to program speedos or they won't do it unless you can prove you have a valid reason for it to be changed and can provide proof of the actual milage on the car, you have to send them to speedo repair shops (I can send you a link of one if you PM me) to get them changed. The PCM DOES NOT store any info for the speedo. It only send a signal to the speedo and the display stores the milage. It takes very little memory for the display to remember the numbers.
