my going super rich on decel issue - new clue found
Old Oct 17, 2005 | 03:32 PM
Blackbird's Avatar
I can't remember off the top of my head.
I will have to check tonite when I get home.
Didn't drive the car today and thats where the laptop is.
Old Oct 17, 2005 | 03:40 PM
frcefed98's Avatar
Old Oct 17, 2005 | 04:51 PM
WS6FirebirdTA00's Avatar
i just lowered the pulse width and my trims are still going way negative, im going to check it with the WB right now.
Old Oct 17, 2005 | 07:53 PM
the WB confirmed that it was rich, my pulse width is about 1.8 ms, and the min pulse width is set to 1.003. any ideas?
Old Oct 17, 2005 | 08:30 PM
SmokingWS6's Avatar
Originally Posted by Blackbird
Give the man a prize. Dropped the values down to 1.003 and it fixed it!
Now I just have to go fix the low end of the VE table I screwed up so bad trying to overcompensate
Thanks for the tip SmokingWS6! I am glad I wasn't too stubborn to not try your suggestion.
Glad to hear it worked out, there's always that hidden table that causes all the trouble.
Now about that beer
Old Oct 17, 2005 | 08:32 PM
SmokingWS6's Avatar
Also edit the Default Plusewidth and Short Pulse Adder.
Old Oct 17, 2005 | 08:53 PM
i changed the default pulse width, what should be done to the adder?
Old Oct 18, 2005 | 06:12 PM
to the top, i pulled out fuel, adjusted the min pulse width, default pulse width and short pulse adder i mult by 0.5. on decel i still see 1.8-1.9 ms and im running about 11.5-12.5 on the WB. this is eating up tons of gas and is a pain with bucking so please help!
Old Oct 18, 2005 | 06:15 PM
frcefed98's Avatar
Lets get a clear overview of what we need to correct to get this damn over rich condition to cease.
Step by step for us slow guys.
J
Old Oct 18, 2005 | 06:31 PM
Old Oct 18, 2005 | 06:41 PM
frcefed98's Avatar
hey wait
J
Old Oct 18, 2005 | 08:25 PM
  #32
even with the short pulse adder added to the min pulse width its going to about 1.1 or so, but the car is staying 1.8-1.9 no matter how much fuel i pull out. im just having a hard time seeing this. i already have values in the VE table in the teens
Old Oct 19, 2005 | 11:03 AM
  #33
Blackbird's Avatar
J- you running 60# injectors?
if so I will just send you my current .bin and you can cut and paste what you want or just try it out.
should work just dandy for 9psi or less on 91 octane.
it's not optimal at this point but it's pretty good.
Old Oct 19, 2005 | 12:28 PM
  #34
can you let the rest of us know what you had to do please?
Old Oct 19, 2005 | 12:32 PM
  #35
Blackbird's Avatar
only thing I did to finally get it in line was as I said changed the min pulsewidth to 1.003
other than that, standard tuning and making sure I didn't have any vacum leaks, my o2's were good, no exhaust leaks, etc...
Old Oct 19, 2005 | 01:48 PM
  #36
well **** i already did that on the injectors, maybe i need to set them lower. they arent going below 1.9 ms. when you changed yours how much lower did they go?
Old Oct 19, 2005 | 03:54 PM
  #37
Blackbird's Avatar
no idea, I would have to log and look.
I have been basing everything off my wideband.
Old Oct 19, 2005 | 05:01 PM
  #38
well i lowered the pulse width, i guess the injectors i am running are just too big to cut anymore fuel out. **** on it ill just adjust dfco so itll cut out the fuel lol
Old Oct 19, 2005 | 05:04 PM
  #39
Blackbird's Avatar
what is your base fuel pressure? mine has been lowered to 50.
maybe thats why it works for me and not you?
Old Oct 19, 2005 | 06:07 PM
  #40
frcefed98's Avatar
cool buddy, I have mototron 60s too. Go ahead and send it to me, jsbird1998@comcast.net
I'm putt putting around on 5psi right now
Thanks heath,
