How do I get IAC counts in scanner?
Old Oct 13, 2005 | 03:10 PM
00Z28SS's Avatar
Default How do I get IAC counts in scanner?
up top
Old Oct 13, 2005 | 04:13 PM
horist's Avatar
um.. you add them ...
I'm assuming you're using HP Tuners.. if so you just right click.. select it from the list and double click...
if you have more than 24 bytes used (you'll see the byte count up top) then you need to remove another sensor first...
This is all done in the table display (as is explained in the help file)
Old Oct 13, 2005 | 07:46 PM
silverTA2002's Avatar
It doesn't really explain it well in the help file, especially if you have one of the earlier HPtuners and haven't updated.
Don't worry, I didn't know how to do it till about 2 weeks ago. And I've had HPtuners since April 2004.
Pull up the table display. Highlight a cell and delete one. Then right click and insert whatever you want from the list.
When you right click any parameter, you can select Imperial or Metric for the values.
