02 Sensor Codes... How To Get Rid...
Old Oct 15, 2005 | 04:04 AM
s.o.m.SS's Avatar
Default 02 Sensor Codes... How To Get Rid...
My Car Is Throwing The Driver Side O2 With All 02 Codes... I Have Cam, Long Tubes, Off Road Y Pipe... How Can I Manually Reset The Comp? Ps The O2's Are New
Old Oct 15, 2005 | 07:05 AM
TAQuickness's Avatar
pull the pcm fuses while the car is running. that should reset the pcm. you might also look into a set of bosche 13111's.
a little search will dig up a bunch of info on this topic.
Old Oct 16, 2005 | 07:55 PM
Bill Bowling's Avatar
Talking
Using the Bosch 13111's O2's cured my codes.
Bill
