Case Learn
Old Oct 15, 2005 | 07:10 AM
LS1PWR's Avatar
Default Case Learn
I would liek to go from an 00 OS to an 02. I was told that I was told that I would have to do a Case Learn on the OS. I will be changing this with HPTuners. I am under the impression that all I need to do is do a complete rewrite on the PCM with the 02 OS. Is this correct?
Dave
Old Oct 15, 2005 | 07:35 AM
TAQuickness's Avatar
IIRC you will need to use the HPT scanner to initiate a case relearn. Should only take about 30-45 seconds to perform.
Old Oct 15, 2005 | 11:44 AM
LS1PWR's Avatar
What is IIRC?
Dave
Old Oct 15, 2005 | 11:51 AM
horist's Avatar
IIRC = If I Recall Correctly
Just internet jargon like LMFAO, FWIW, etc...
Andd he is correct... it's in the VCM Scanner , part of the VCM Controls
