Intermittent Starting on LS1 '99 C5 Hardtop
I've done as much as possible that I know of. Here goes.
I've tested the starter. (I talked to a starter mechanic to understand how they work and he indicated that the contacts could be remaining in an open position therefor preventing any turning or sounds whatsoever....so I had it tested.)
I've tested and essentially dismantled (twice) the Clutch Pedal Switch found under the clutch pedal arm.
I've had the ignition cylinder replaced.
I've had the keys tested at the GM dealer and apparently they're "tight.".
I've had an "interrupt relay" replaced. (I'm not sure if this is the same as the starter relay.
I've had the steering column lock replaced. I've even temporarily installed a CLB for lack of any other ideas!
I've pulled the fuse box in the passenger side and checked every single fuse.
I've put a brand new battery in it and checked the cables.
Description of what happens:
Put the key in the ignition. Turn it to the right. All the gauges register, fuel pump is heard (if the window is down), then nothing. I do here the relay click if I pump the clutch pedal. The switch at the clutch pedal triggers the relay on the passenger side so I can tell that's connecting. I don't get any messages on the DIC. I don't get any turning or any other sounds. It doesn't seem to matter if the air is on or off, radio on or off. I turn them all off anyway. I'll sit there and play with the key. Back and forth, in and out and even just take it out and wait a minute or two. It usually starts at some random moment. Keep in mind this has happened now for the past two years and only recently appeared to be worse. It has happened to the extent where I've not been able to start it so I've actually been in a few situations where I've had to have it push started. That's another reason I don't think it's related to the Pass-Key system and anti-theft mechanisms because then the car wouldn't be allowed to start. I'm at a loss. I've had it in to a mechanic that works only on corvettes three or four times and it's started every single time for him. Go figure. Any help whatsover is greatly appreciated.
Thanks again.
Michael
