AFR question before & after cats.
Old Oct 21, 2005 | 10:08 PM
terry s's Avatar
Default AFR question before & after cats.
I would like to put a wide band on my 02 Z06. FJO tells you to put the 02 sensor at least 18 inches from the exhaust valve but in front of the cats. Room is limited and the pipe ahead of the cats is double wall making installing the 02 sensor ahead of the cats not very practicle.
FJO says some newer cats have little effect on the AFR but some can cause the reading to be off by as much as 1 AFR.
Has anyone done any comparison readings on an 02 Z06 to see what the difference in readings is between before the cats and after the cats? If I knew the difference then I would know how to compensate the tune having the 02 sensor after the cats.
Old Oct 21, 2005 | 10:16 PM
HumpinSS's Avatar
Here is some good reading about your question. I think it does a pretty good job explaining the cats operation
Old Oct 21, 2005 | 10:21 PM
terry s's Avatar
Thanks for the link and the quick reply. Which section has the infromation I need.
Old Oct 21, 2005 | 10:27 PM
HumpinSS's Avatar
LMFAO i didnt give you the link beeer owns me
http://www.ls1.com.au/forum/showthread.php?t=34016
Old Oct 21, 2005 | 11:08 PM
terry s's Avatar
Thanks for the link. Good info there.
Old Oct 25, 2005 | 03:42 PM
Ed Blown Vert's Avatar
I would be interested if there is a difference too.
Old Oct 26, 2005 | 12:30 AM
kbracing96's Avatar
You must not have read the link
