Issue with RAF table and STIT/LTIT
Old Jan 3, 2006 | 09:26 PM
Dixit's Avatar
Throttle Follower Airflow vs TPS
Code:
0.04395	0.04590	0.05078	0.06543	0.09570	0.14844	0.22656	0.35059	0.51660	0.65332	0.73535	0.77344	0.78711	0.79492	0.80078	0.79785	0.80078
Throttle Follower Decay Gear vs Speed
Code:
0.01270	0.01953	0.02930	0.04004	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055	0.06055
0.01270	0.01953	0.04004	0.06055	0.08008	0.09961	0.12012	0.15039	0.20020	0.20020	0.20020	0.20020	0.20020	0.20020	0.20020	0.20020	0.20020	0.20020
Heres what I ended up modifying my two tables to from what Phil sent me and this has worked out alot better too. Phil's tables I noticed it would dip too much on coming to a stop.
Dixit
Old Jan 3, 2006 | 09:48 PM
Phil99vette's Avatar
7 Second Club
Interesting....
Old Jan 3, 2006 | 09:53 PM
7 Second Club
I'm gonna try them on one of my new builds.
Phil
Old Jan 3, 2006 | 10:10 PM
JimMueller's Avatar
I had excellent results with the reduction of bucking. I too noticed it dipping too much coming to a stop, and didn't realize there was new info in this thread. I'll try the same alterations Dixit mentioned above.
Old Jan 3, 2006 | 10:29 PM
Bink's Avatar
Originally Posted by Dixit
0.01270 0.01953 0.04004 0.06055 0.08008 0.09961 0.12012 0.15039 0.20020 0.20020 0.20020 0.20020 0.20020 0.20020 0.20020 0.20020 0.20020 0.20020[/CODE]
Dixit
Thanks Dixit!
Once my car is back together I'll try them. I copied the original tables you posted into my EFILive file - but wasn't able to test them.
Old Jan 3, 2006 | 10:31 PM
JimMueller's Avatar
That took care of my idle dipping issue. I'm not sure if I'll get out to give it a test drive tonight, but if not I'll drive it to work tomorrow and report back.
Thanks Phil and Dixit!
Old Jan 3, 2006 | 11:53 PM
JimMueller's Avatar
Took it out for a test drive. It still dips down a bit below idle on a very hard stop followed by a sharp turn. Even then, the steering wasn't dying on me like it had been.
Old Jan 4, 2006 | 05:28 AM
ringram's Avatar
You can probably mess with the cracker and up it a little more in the area where you are still having problems.
Old Jan 4, 2006 | 08:15 AM
Bink's Avatar
Might want to look at Accessory airflow and Torque.
