2.0 wideband histogram not working?
with 2.0 I redefined my wideband, it shows up in the logs just fine yet the a/f historgrams for doing VE only show values of zero.
whats the trick to get it to work?
you might just have something simple you are missing...
I had the same problem with my Zeitronic WB.
Simple fix.
Goto 'options' in Histogram & 'change/insert' the PID to whatever you 'named' your WB O2 sensor.
It's in the pull-down AUX list under 'user defined, after you click insert/change PID.
When I named my WB O2 I also chose 'Air Fuel Ratio' as the sensor, & 'afr' as the units.
I did start to muck with that but only really quick, was doing this in the driveway on the way to work this morning. Was going to do some SD logging then saw oh crap the histi doesn't work so I flashed back to my MAF tune real fast and drove to work.
I do definetly appreciate 30 second flashes
