How can i fix the Reduced Engine Power ?
Old Nov 6, 2005 | 03:45 AM
oOoLy's Avatar
Default How can i fix the Reduced Engine Power ?
How can i fix the ( Reduced Engine Power ) by the LS1Edit in the 97 C5 ATI ??
Old Nov 6, 2005 | 09:23 AM
HumpinSS's Avatar
there is a table for ETC predicted airflow or a param you need to increase this by 10-20% and it will stop throwing P1514
Old Nov 7, 2005 | 09:16 AM
oOoLy's Avatar
Thanks HumpinSS ....
Do you mean to increase the :-
- The max maf airflow ETC ?
- or the High MAF Fail MhZ ?
- or the DTC P1514 Calc Airflow ?
Old Nov 7, 2005 | 10:10 AM
HumpinSS's Avatar
increase DTC p1514 Calc airflow
Old Nov 7, 2005 | 04:47 PM
oOoLy's Avatar
So i will multi by 120% ??
Old Nov 8, 2005 | 09:33 AM
Dixit's Avatar
Yes if you multiply it by 1.20 you should be fine.
Old Nov 8, 2005 | 05:23 PM
oOoLy's Avatar
multiply it by 120 or 1.20 ??
Old Nov 8, 2005 | 05:43 PM
Dixit's Avatar
120% equls 1.20. If you multiply a number in the cell by 1 you get the same number, because its 100% of that. If you mutliply the number in the cell by 2 you get twice as much now because its 200% of that.
Dixit
