Passing gear...
Old Nov 8, 2005 | 11:35 PM
hunterdawgs's Avatar
Default Passing gear...
Is the passing gear initiated by the PCM because mine quit working after header install and messing with the Predator?
Old Nov 9, 2005 | 07:53 AM
UnleashedBeast's Avatar
Did you retune your car back to stock and see if it fixed your problem?
Old Nov 9, 2005 | 08:16 AM
Ragtop 99's Avatar
The converter unlock and downshift are controlled by the pcm. They use a table with MPH & TPS% as the inputs.
