Question about O2 behavior in OL/CL
The reason they oscillate is that the PCM is constantly adjusting the fueling to maintain an average of 14.7:1 ... so the PCM is constantly adding and removing fuel which results in high low high low oscillation ... at WOT you're just dumping fuel in without removing any... thus no oscillation
and 880-920 doesn't necessarily mean it's closer to 12.8-13.0 ... 880 is a little lean for my tastes (for narrowband tuning) ... but there really isn't much correlation between an AFR and a O2 voltage output (narrowband are only accurate for a very narrow range of AFRs)
And... not a good idea to disable PE (Since you seem to be doing SD tuning w/out a wideband... you can only safely tune lower RPM lower loads...) ..... 14.7:1 at high load is a good way to blow your motor up... high load high RPM SD tuning simply can't be done safely and accurately with a narrowband sensor... Part throttle driveability can be tuned safely and accurately but once you get to higher loads and RPMs... 14.7:1 AFR is NOT a good thing...
I would turn PE back on or avoid high load or high RPM... unless you enjoy detonation...
edit - quick question about when I had PE disabled earlier...if it did start detonating would I get some KR for a little protection or not?
