tuning newbie
Old Nov 13, 2005 | 08:42 PM
1LoudTA's Avatar
Default tuning newbie
just got hptuners 2.0 from a buddy of mine. ran my car on a dyno and my a/f ratio went to 11.8:1 above 4000 rpms. How can i lean it out a little bit where it needs to be on hptuners?
Old Nov 14, 2005 | 12:12 AM
DramaFoYoMama's Avatar
I don't use HP Tuners, so I can't tell you where it's at, but you need to lean out your PE table above that RPM. It sounds to me like your VE table hasn't been worked either. Have you done any part throttle tuning? WOT is only part of the tune.
Old Nov 14, 2005 | 12:28 AM
TAQuickness's Avatar
the stickies have some good write ups that should help you get a better idea of how the tables relate to each other and which ones you would need to adjust
