best years for FI tuning?
I'm putting a 383 with an STS turbo kit in it.
I know the '98 pcm has some issues/constraints - no 2bar support, auto tranny doesn't like mafless, something about VE tables, maf max frequency supported, etc.
The car is completely apart right now. Engine is out, dash is out. Would be easy to switch over to another year right now.
If I was going to switch to another year pcm and harness, which year(s) would be best, and why?
the only diff between them will be minor stuff.. for example 99s and 00s had EGR.
the best software years were the last 2... 01 and 02..
what you can do is get any 99-02 harness/PCM and have someone flash it as a 02.
then you have the most up-to-date software... and you'll be set to upgrade to 2bar support...
