LM-1 vs. Histogram: AFR
Old Nov 19, 2005 | 05:22 PM
Sport Side's Avatar
Default LM-1 vs. HPTunes Histogram: AFR
I'm using a LM-1 WB unit to tune my A/F ratio. I'm having a problem with
my A/F ratio showing coordinating values with the LM-1 unit. First of all,
I know my LM-1 unit is accurate.
The Histogram allows me to enter WB operation but all values are 12.7
A/F. I also noticed that the A/F correction histogram display is not access-
ible.
I "think" I set my LM-1 manager up correctly.
0V=10AFR
5V=20AFR
Do I need to change lambda?
In my opinion, it seems the histogram is recognizing the LM-1 unit other-
wise the 12.7 values would not be showing. This then suggest to myself
that something is not "Set up" correctly.
Any help would be greatly appreciated, Thanks.
Kyle
Old Nov 21, 2005 | 11:12 PM
Dragman's Avatar
TTT for ya!
Old Nov 23, 2005 | 02:24 PM
Sport Side's Avatar
Any input? I'd appreciate it.
Old Nov 23, 2005 | 02:48 PM
horist's Avatar
which input on the EIO are you using? if you're using hte first input everything should work ...
In the table display you have an option to add raw voltage, see if it fluctuates... 12.7 is a default I believe if there's no input detected ...
Old Nov 24, 2005 | 06:11 AM
Sport Side's Avatar
Originally Posted by horist
which input on the EIO are you using? if you're using hte first input everything should work...
I'm not sure what you mean by, which input. Could you elaborate?
I'll check raw voltage. Thanks.
Old Nov 26, 2005 | 10:31 AM
Sport Side's Avatar
Figured it out.
I had it set to the wrong cell in the table display.
Thank you, Kyle
Sport Side's Avatar
Figured it out.
Thank you Horist, Kyle
