Running OpenLoop SD and Due Inspection-Help with P0103?
Old Nov 20, 2005 | 03:22 PM
Bill Bowling's Avatar
Talking Running OpenLoop SD and Due Inspection-Help with P0103?
I am running Open Loop with EFILive COS 3. I am due inspection soon and need some help. I was told the P0103 MAF code will cause it to fail the ODBII inspection. I re-installed the MAF and hooked it back up but I still get the code. I know I need to change a few items but am not sure what. I was going to re-program my PCM with a old problem before open loop but thought if I could just change a couple of items it would be easier. What does everyone think? Anyone have this problem before inspection?
Will I need to go back to the stock OS to do this or can I just flash an old cal into the EFILive OS?
Bill
Old Nov 20, 2005 | 06:53 PM
Another_User's Avatar
Bill
Did you reset the computer? The MAF fail code may not just go away.
Old Nov 20, 2005 | 09:34 PM
TAQuickness's Avatar
you need to set all your MAF fail settings back to stock. You should be fine running the custom OS. I'll be due for inspection by the time I get my top end back together (but I'll probably stretch it a few months for the hell of it) and will be trying to pass inspection with !maf. I'll let you know how it goes.
Old Nov 20, 2005 | 10:02 PM
WS6FirebirdTA00's Avatar
well my car passes inpection, as long as the MIL light is not on the comptuers here in NC wont look for DTC's. if a light is set it looks.
Old Dec 8, 2005 | 10:32 AM
Talking
I setup a special tune that I put in the PCM right before I got to the station. I did place the MAF back on but probally could of left it off. Passed like a charm. No DTC's and all readiness test completed.
Bill
