Filtering bad values in HPT 2.0
Old Nov 22, 2005 | 07:14 PM
rush7's Avatar
Default Filtering bad values in HPT 2.0
I was playing back my histogram for a session trying to dial in my VE's with my wideband taken this morning and I noticed a few of those values are really off--as in close to 0 afr. I don't imagine that is what is really taking place, and I would like to throw those frames out of my histogram so it doesn't screw up my averages. I can't figure out how to throw out individual frames (and that would be tedious), but I was wondering about the filtering function on the histogram. How I can access my wideband on EIO port 1 when writing the formula to kick values out of the histogram? I don't see the sensor in the help list that shows all the SENS and PID's. How do I filter those bad values out by setting a threshold on the wideband, or is that possible?
Old Nov 22, 2005 | 07:19 PM
Magnus's Avatar
LS1TECH Sponsor
If your wide band is defined as an AFR sensor (which it most likely is)..
you would use the AFR sensor in the Sensor list to filter against.
Old Nov 22, 2005 | 07:24 PM
rush7's Avatar
OK, it is defined as a wideband now. I think I see how to do it. Thanks!
