SD tune problem ?
Old Nov 25, 2005 | 02:26 PM
oange ss's Avatar
Default SD tune problem ?
tryin to tune in SD w/ WB, followed instructions per HPTuner help file. Set up VCM per help file. After loggin, W/B says I'm runnin lean down low, 16.7 -22 depending on MAP and RPM, but NB voltages are in line with LTFT readings (898, -2 respectively)....any help would be greatly appreciated...thank you
Old Nov 25, 2005 | 02:30 PM
oange ss's Avatar
log file
http://members.***.net/orangess/25novSD.hpl
Old Nov 25, 2005 | 02:44 PM
oange ss's Avatar
nevermind, i dont know what the hell happened but my VE % error was showing anywhere from 22-53% lean, AFR was showing 16-22, I closed the log and reopened it and everything is showing normal now....must have a bug in the program somewhere...Magnus ??
p.s. but feel free to check the log out if you get bored
