electromotive tec 2 help please
Old Nov 26, 2005 | 02:36 PM
quickcj-7's Avatar
Lightbulb electromotive tec 2 help please
hello im am very new to this fourm and need to ask a few questions to guys that use a electromotive tec 2 on their ls1
the motor came out of a 98 firebird it will be going into a Jeep cj-7
I need to know which stock sensors i will have to use or need to use
where the sensors are located
are there anything I need to know about the tec a running a certain fuel pres
do I use a knock sensor and will the stock one will work with the tec 2
what will happen and do I need to use 1 oxygen sensor or both (i dont think I can use both) and will the stock sensor work ?
I think I need to retrofit a crank trigger system with a new 58 tooth wheel and pickup (unless stock trigger can be used)
will the stock maf or map sensor work ? does it even have a map sensor ?
anybodys help,setup info, or pictures would greatly help .
thanks for you time
Old Nov 27, 2005 | 12:04 AM
94SS's Avatar
Try www.kennedysdynotune.com he specializes in Electromotive.
