HP Tuner 2 bar + MAF, will it work for boost?
hows that for a start and an example
usually you also have to change your OLFA table to reflect teh same changes because it has a MAP referenced data, and your PE tables all go to different #'s as well...
timing maps change....there are just a ton of tables that will be effected by a 2 bar MAP on a PCM that has a 1 bar data set
