3:42 to 3:73's
Old Nov 28, 2005 | 03:15 PM
YO-EL's Avatar
Default 3:42 to 3:73's
A4 car.
What exact changes need to be made to shift points..?
Scaled up by a certain % ?
And do WOT shift pts also need to be changed?
Old Nov 28, 2005 | 03:32 PM
horist's Avatar
depends on what software you're using...
I know with HP Tuners it will scale the tables for you automatically (speedometer->speedometer enter tire size and gera size, and leave "Auto Scale Transmission Tables" selected)
I believe EFI Live has this ability also
If you're using LS1 Edit then yes you can just scale the shift tables by a percent (part throttle and WOT) the scalar would be 91.69% (since RPMs will be higher, MPH will need to be lowered) I believe you'll also want to do this to the torque converter tables
