Pe table question/ifr
Eric
Simply put, all PE does is tell the car what AFR to be at when you are at WOT.
However, in order to achieve that AFR the PCM has to have the correct data. All your other tables are going to do is tell the PCM how much airmass is in the cylinder. It takes that calculated airmass and divides that by what AFR you run and gets the amount of fuel to add. It then uses the IFR table to determine how long the pulse width needs to be to add the correct amount of fuel.
This is a VERY SIMPLIFIED idea of what is going on in there. Basically, if you don't have the IFR correct you won't get the correct air/fuel ration you are commanding via the PE table because the PCM doesn't really know how much fuel its putting in there. Of course, if your VE/MAF isn't right then it has no idea how much air is in there either... which is why we tune
