Afterstart Enrichment Table Question
Old Dec 2, 2005 | 05:07 PM
Billiumss's Avatar
Lightbulb Afterstart Enrichment Table Question
I know what it does but since it's an adder, what does it add to, the OLFA?
Check out the pic:
Attached Thumbnails Afterstart Enrichment Table Question-afterstart-enrichment.jpg
Old Dec 2, 2005 | 05:21 PM
HumpinSS's Avatar
that table is pretty straight forward if your olfa table is set to 1.00 and you have a .25 in your After start enrichment table at that ect your final afr is be 1.25 or 11.75 upon startup.
Old Dec 2, 2005 | 05:42 PM
Billiumss's Avatar
So it does add to the OLFA table, interesting.
Say my coolant temp is 68 degrees F and after I first start the car the MAP goes to 40kpa and my OLFA value is 1.10, the Afterstart Enrichment table will ADD .250 to the OLFA value, correct?
So if that is true then 1.10 + .250 = 1.350
1.350 would equal a 10.88 A/F!
No wonder why I have black "water" coming out of my tail pipes onto my driveway on a cold start.... That would also explain why my wideband LM-1 reads "Too Rich" on a start up for the first 5-10 seconds...
Bill
Old Dec 2, 2005 | 07:58 PM
Ragtop 99's Avatar
There is another table that determines how long it kicks in for. I've left the adder alone to be sure it fires, but shorten the length of the enrichment period where there is a hump in the table.
Old Dec 3, 2005 | 08:12 AM
Billiumss's Avatar
Exclamation
This looks like the table your talking about, but it can't be in RPM's, it has to be something else because 100 RPM's would be over in milliseconds after start up:
What do these other tables do:
Old Dec 3, 2005 | 09:03 AM
HumpinSS's Avatar
the are time and rate tables. I didnt feel like fooling around with em to much so i just messed with that added table actually i 0'd it out form 3* on up to 284 and it cured hot start problems also and surging when first cranked
Old Dec 3, 2005 | 10:16 AM
Ragtop 99's Avatar
I assume it is in RPMs beacuse the delay is saying it waits 3 - 6 seconds (based upon a 1000 rpm start-up) and then it starts to reduce the enrichment.
Old Dec 4, 2005 | 04:30 PM
gameover's Avatar
it works like this:
1. the two initial adders are summed and form the start point for the enrichment. This value adds to the openloop eq.
2. there is a "decay delay" which is how long the initail adder is held before it begins it's decay to zero. the delay is in engine revolutions.
3. the "Decay Step" and "Decay Mult" determine the rate of decay to zero.
This is basically an "automatic choke" function.
Chris...
Old Dec 4, 2005 | 09:10 PM
WS6FirebirdTA00's Avatar
i used the adder from the 2002 bins, made it decay faster and set the OLFA to 1.00 then worked with the friction airflow to keep the rpms from hanging on start up. saves a lot of gas on start up and still fires fine.
Old Dec 5, 2005 | 06:58 AM
Billiumss's Avatar
post a few of the tables that you have changed, I'd like to see them.
Old Dec 5, 2005 | 08:14 AM
no... lol jk, when i get back home i will try to, if i dont post by tonight then pm me or somethign to remind me please
Old Dec 5, 2005 | 06:36 PM
here you go, let me know if you need anythign else
Attached Thumbnails Afterstart Enrichment Table Question-startup.jpg   Afterstart Enrichment Table Question-startup2.jpg
Old Dec 5, 2005 | 07:09 PM
P Mack's Avatar
100 revs would take about 8 seconds on my car, what is your idle speed set at to get 100 revs in milliseconds?
Old Dec 5, 2005 | 07:16 PM
P Mack's Avatar
I'm not seeing the soaktime table, is it because i'm not running hptuners 2.0?
Old Dec 5, 2005 | 07:47 PM
what is the soak time? hell i dont see anything like it in mine and i have 2.0
Old Dec 5, 2005 | 07:57 PM
P Mack's Avatar
I wish i had it because i bet that explains why my car tries to die on hot starts, but only after it's been sitting for a while.
Old Dec 5, 2005 | 08:16 PM
i cant find anything associated with that in my tune.
Old Dec 5, 2005 | 10:05 PM
Firehawk526's Avatar
Interesting you guys bring this up, as I ran the autotap on my Hawk last weekend, and couldn't isolate on why my car "on cold starts" will surge for about 30 secs between 400 -750 rpms and then idle right out at 750-800 rpms.
Now I did recently install a ported TB, but this problem began about 2 months after install, and we cannot determine why.
Any guesses?
Old Dec 5, 2005 | 10:18 PM
if its surging its got to do with fueling, did you close the iac hole with epoxy at all? maybe you arent getting enough air (but that would more or less cause a low idle).
Old Dec 6, 2005 | 02:03 PM
Sorry to get off topic, but I thought I may have stumbled onto something reading this thread, but yes it has been sealed off, and the idler screw is turned all the way up.
Thanks for the response.....just fricked weird, but I guess a full blown tune will catch this when I get the cam installed next year. Meanwhile, I will just have to deal with the problem I guess. No harm, no foul!
