maf translator
Old Dec 3, 2005 | 07:53 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default maf translator
could i use a maf trans to adjust my a/f and add fuel right now its 15:1
Old Dec 4, 2005 | 12:31 AM
horist's Avatar
short answer yes... but it's best to find out why your car is running that lean...
You're talking about WOT right? (part throttle should be around 14.7:1)
I would check fuel pressure... a clogged filter, failing pump could cause that... also do you have any SES lights?
Have you recently reoiled your K&N filter? If so oil prolly got on the wires for the MAF and is causing incorrect readings
The MAF Transalter is a bandaid fix (if any) .. I would try to find the real problem first
Old Dec 13, 2005 | 10:53 AM
LS1Tech Sponsor
im gonna clean my maf today i read about the k&n and i never thought about it so im gonna try and clean it and i have a egr air & rear o2 light
Old Dec 14, 2005 | 10:30 PM
SmaknaSS's Avatar
I got one for sale for $65 if your still interested.
Old Dec 15, 2005 | 02:03 AM
LS1Tech Sponsor
na an im gettin it tuned sat i was supposed to today but his system was having a problem but i cleaned my maf and it made it like 80 percent better
