Need quick help with a wire harness.
Old Dec 3, 2005 | 09:34 PM
gearheads78's Avatar
Default Need quick help with a wire harness.
OK I'm not sure if this is the best place to ask but does not seem to be a place for everything else questions.
I am building a Frankanstein car consisting of many differant years and parts.
Started as a 98 M6 car but now have an A4 98 body and dash harness with what I has told was a 2000 engine harness and a 99 PCM
Its been about 6 months since it was taken apart and tonight I'm trying to button it all back up. I have two plugs I can't remember what they went to.
One is a white plug off the dash harness right next to where the two engine harness plugs are. The other is a black one in inside the console at he front of the factory shifter.
Please help. I'm stumped!
Old Dec 3, 2005 | 10:18 PM
John_D.'s Avatar
The black one is cigarette lighter.
The white one should match a dangling socket under the dash in that same area.
Old Dec 3, 2005 | 11:53 PM
I know which one is the lighter. I am talking about the multi pin connector right in the center of the pic.
On the other one there is no extra plug hanging. Just the one you see in the pic. Thats why I mentioned the 98 body harness with the late engine harness.
Does someone know if that is a 98 only plug and if so does anyone have the 98 wire diagram.
Old Dec 4, 2005 | 10:39 AM
slow's Avatar
The one under the console is for a Firebird TCS switch.
Ryan
Old Dec 4, 2005 | 11:18 AM
Ryan
Thanks I figured it out last night. A also have found out the 98 and 99+ engine harness is not the same. I'm trying to find someone with a 98 shop manual locally today to get the schematics.
Old Dec 4, 2005 | 11:32 AM
bullygoat's Avatar
White plug is connector C210, It has fuel tank wiring, level sensor pressure sensor etc. I'm looking under a 98 and 00 camaro. The 98 has this plug in its harness and the 00 harness doesn't. Looks like in 2000, GM added the wires in this connector to connector c230. Actually condensed 5 connectors into 2.
Tim
Old Dec 4, 2005 | 01:11 PM
Tim thanks a ton
I have a 2000 shop manual here so I can look it all up. If you have a 98 one there I would be forever grateful if you can break down following 4 connectors for a 98. Once I have that info I can make it work.
c105
c210
c220
c230
Thanks Richard
