wideband w/ true duals?
Old Dec 6, 2005 | 12:42 AM
TINKRD's Avatar
Default wideband w/ true duals?
Anyone running this setup?
I might be getting a wideband soon so i can monitor when i spray the N20.
Anyone run one w/ duals?
I dunno where I would place the 02 Bung?
Old Dec 6, 2005 | 01:30 AM
soundengineer's Avatar
well..I am....
I am running an Open Loop tune at the moment...I put the O2 in the bung already in the longtubes that was made for the stock o2.
I just wired my Wideband to also output narrowband stuff so I will be testing that out as soon as my new sensor arrives(old one went bad....it happens)
usually you want the o2 in the collector and no more than 18" away from the primaries if possible...
Old Dec 6, 2005 | 10:02 AM
Project GatTagO's Avatar
FJO makes a dual wideband controller if you want to get really fancy.
Andrew
