RPM tach help
Old Dec 7, 2005 | 09:49 AM
A Mustang's NightMare's Avatar
Default RPM tach help
Well I first ask in the ls2 ls7 forum. My RPM tach doesnt work, but I dont get acurate responses.
To start with the CAM sensor, the red wire has 10 volts, pink wire is ground, and brown wire is signal I'm I right or wrong ?
The code that the cam is trowing is PO343 (Camshaft positioning sensor High output) that code was with the wires the wrong way. But it still not working after I switch them.So I'm thinking the cam sensor is bad
I'm also getting a PO153 O2 sensor slow response. Is the O2 going bad ?
