LS1 Edit and a Th350??
Old Dec 8, 2005 | 05:06 AM
URLOSN's Avatar
Default LS1 Edit and a Th350??
I just got my Rossler th350. i have searched and i see that people are saying that you have to change a few things and disable other's. i bought LS1 Edit so i could change my tunes, and basic stuff. can anyone give me a step by step of what i need to change, and where i need to go in Edit to get to these features to change them. also i got the 9" tailshaft that uses my stock speedo sensor, so do i have to change anything with the speedometer? since gear ratio's are different inb the Th350 than the 4l60e, atleast 1st and 2nd are.
Help please!!!
David
Old Dec 8, 2005 | 10:39 AM
Bill Bowling's Avatar
Most people here are using HP Tuner or EFILive as their tuning software. I traded my LS1Edit with EFILive. I am sure there are a few people using it still around somewhere .
Bill
Old Dec 8, 2005 | 03:01 PM
BigKID's Avatar
David, take a look at THIS THREAD. Looks like all you need to do is set the PRND to false (if yours is set to true) and delete all the tranny codes and you should be good to go since you are retaining the VSS.
Old Dec 8, 2005 | 05:21 PM
URLOSN's Avatar
sweet kenny, thanks
Old Dec 8, 2005 | 09:34 PM
CAT3's Avatar
Restricted User
I didnt change my PRND... to false. I just deleted all the trans codes that popped up after initial startup, scanned DTC's, deleted codes. The VSS, do you have the Rossler 9" tail with VSS mount bung? And the reluctor ring installed on the tail shaft? If so, simply plug in and yout good. The VSS signal comes off the tailshaft, therefore doesnt matter what internal gears are being used, only rear will effect it.
